newer axles
87silveradok20
Ohio
Levi
Silverado k20
has any body ever tried putting the newer style axles that have the auto locking hubs in them on a squarebody?
87silveradok20
Ohio
Levi
Silverado k20
oh nevermind i forgot they changed to ifs
slowgo
wa
Blake
V3500 3+3
454, nv4500, 205, 4.56 rp
im actually on the hunt for a AAM 1150 axle for my dually. strong as or stronger than my 70, convert to SRW and use factory off the shelf parts for rear disk with Ebrake.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I put front and rear axles from an 89 Suburban on my 86.
Auto hubs were an option (although failure prone) in the 80's.
87silveradok20
Ohio
Levi
Silverado k20
Ok so I will stay away from the auto locking ones
marks86
Latham, NY
Mark
12v Cummins
you could absolutely take a rear end out of a brand new 1 ton truck, the main thing you would have to do would be cut the old spring perches and shock mounts and reweld them in the correct location
87silveradok20
Ohio
Levi
Silverado k20
ok thanks
that came on 10bolt front axles and they sucked
locking hubs vs auto locking hubs
locking hubs win everytime
They were available on the D60 too. Although very uncommon.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
That was the first thing I did when I swapped the axles, Took off the auto-locking hubs, and put in the Warn manual locking hubs. You lock them, unlock them, they work flawlessly every time.
marks86
Latham, NY
Mark
12v Cummins
so you could buy a k30 in 83 with a np203 instead of a np205? that's crazy
Nope, it was still the 205. I don't know the first year for the option, but right around then was when the "synchro" version of the 205 started.
southbaymiller
