Newbie needing help
airjordanbl23
illinois
william
I’m new to working on vehicles. I got a 1983 Chevy K10. The vehicle starts fine but then has a hard time idling without stalling. If I sit and rev the engine for like 30 seconds it will then run fine. Any ideas on how to fix the trouble idling?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
If it runs better once warmed up, the choke may be inoperable.
airjordanbl23
illinois
william
so does the electric choke maybe need replaced?
fast 99
Spokane, Washington
Does sound like a choke issue. When completely cold does the choke plate close? That is the butterfly on front venturi. Butterfly should be just closed when cold and open slightly after starting.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Are you also new to a carbureted vehicle that has a choke? You do know, you need to set the choke before starting the truck. Push the accelerator one time to the floor and release, then crank the engine.
idahovette
Weiser Idaho
Perry
K20-K10
^^^^^^^^you will KNOW!!!^^^^^^
jim8503
