- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Take the top off the Edelbrock and blow out the primary jets in the front bottom of the bowls with compressed air to clear the idle circuits. Install a good ac delco fuel filter. Rock on.
Yeah, why are we suggesting just go out and spend $300 + for a new carb, and conversion BS when a quick cleaning can do the job or other much cheaper less evasive procedures can be tried first???
Chances are the carb got gummed up from sitting, maybe clogged an idle circuit or bowl vent whatever the case may be.
It runs, but runs like ****??? If you don't feel comfy pulling the top off the carb, you might want to try a stiff dose of SeaFoam in the fuel tank. Maybe a full can of SeaFoam to a half tank of gas. That should start to clean up any gummed up junk in the carb and clean your fuel system as you drive it. It might do the job, it might not, but sure can't hurt to try. I've seen it work before. Edlebrocks are picky about being clean. I'd also consider a good inline fuel filter. Maybe just before the fuel pump, and 2 won't hurt either if you want to put another after the fuel pump.
