New guy in Franklin, TN
hikertrash87c10
franklin, TN
CJ
Hi all, just picked up a 1987 350 TBI and having some stalling issues after about 30 minutes of driving and some slight idle fluctation at time as well. I have already replaced the ignition moduel with an ACdelco one and have a new MAP sensor headed my way now. I have 2 young kids so time is tough to work on it but also looking to see if anyone knows a good mechanic around this area that might be able to assist me when needed/possibly look at doing a motor swap. Thanks in advanced!
animal
Lee
c10 silverado
350ish
:welcome:
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
:welcome:
Strick
Dunn, NC
Harold
C20 Crew
Hello there new guy. My SIL just got an 87 350 TBI truck that has similar issues as well. When I get a chance to wrench on it I'll clue you in. Search the site & you'll find similar discussion threads. Good luck.
HS
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Welcome from VA. I also have a 1987 350 TBI. I have done several things to this truck but have not replaced the ignition sensor or the map sensor. I am intrigued because I had an issue once when my truck sounded and felt like it was going to shut off on me when I was at a stop, then I changed the spark plugs and it runs great again. It does have varying differences in idle once started but usually settles down. I know it can use a tune up. I am anxiously awaiting what I learn from your projects. Cheers.
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. We want to see truck pics.
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Welcome. Nice looking truck.
hikertrash87c10
franklin, TN
CJ
HS
Thanks Strick, looking forward to hearing what you discover! Good luck!
hikertrash87c10
franklin, TN
CJ
JS, when my truck started running really rough the ignition sensor made all the difference in the world. I have a vac gauge on order now to start testing that out and then will look into spark plugs next. which brand did you go with? did you do wires as well- if so which ones? Thinking about a fuel pump next as well, put a gauge on it last week and it sat right around 10psi. Does anyone know what psi it should be reading?
PeteJr
NW MS
GMC Sierra Classic 1500
Welcome from NW Miss.
Good truck shows near Nashville & Lebanon.
GTX63
Tennessee
Ty
Welcome from Northeast Tennessee.
WFO
Texas Panhandle
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I used AC Delco plugs and the Advance Auto knock off wires. Got them all at Advance.
F1r3truck
