New Guy-84 C-10 Questions??
239Design
PA
Scott
C-10
Hi, I just bought a 84 SB C-10. It has been changed up over the years with a different motor (350??) it also has a top loader 4 speed in it that I'm not sure if its stock for a two wheel drive truck? Dual tanks and a gauge that doesn't work. So please bear with all my questions. Also there are no badges on the out side of the truck but it does have a Silverado badge on the dash? I will try to add a pic. Is the daul tank common??Thanks Scott
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Welcome, dual tanks were pretty common. Most non working gas gauges are a bad ground. Do a forum search for some good troubleshooting threads. It could also be the tank switching valve.
Is the option code sticker still inside the glove box door? You can figure out the trim level based on the option code.
I can't help with your tranny question.
gpmorgan
Tupelo Ms.
greg
Welcome to the forum Scott. Great looking truck!
SWSS
NETN
Anthony
Welcome. Nice ride.
Sent from my iPad using Tapatalk
So you want the badges?
Boone83K10
Boone, NC
Benjamin
I (along with many others) can help you with that dual tank setup. I just went through mine in May to get it back up and running.
A present for you to enjoy...
das5439
