New Daily Driver (Caprice)
4WDKC
Southern Florida
Kacy
Did it win? Lol
pretty sure it did but was drivers 3rd pass ever. It started as built to be quick and reliable so he could drive it to work if he wanted, then the 410s, 4k stall and 454 with a huge cam and edelbrock heads went in. Full interior, functional AC and gets better mileage than you would think.
How many electrical prongs on the back of the low beam???
Three. That makes sense since there’s two on the high beam. I’ve never watched someone else switch a sealed beam so I’ve never seen the handoff to the other filament in person. I just assumed that they always remained static while the lights were on. That’s what assuming gets me, though.
73c20jim
Tombstone, AZ
Somehow, though knowing better, I was thinking it was the other way.
73c20jim
Tombstone, AZ
But I have a round eye, so its simple.
Heres the one my friend had. I thought it had tinted windows, still was a sweet car. I was a wee jealous.Thats my burban in the back.
That’s some Caprice porn right there! I like those rallies. I will say they look slicker with the base model or just the Classic since there’s no landau top, but that looks great. I imagine I’ll get tired of the spokes going clink clink on bumpy roads sooner rather than later.
idahovette
Weiser Idaho
Perry
K20-K10
Does yours have the retaining bolt in the middle of the cover? My folks had an 80 Caprice Classic new and at about 20k miles the covers started "walking " and mad a weird noise. Figured out it may have been the wheel itself flexing because of everything being made lighter for gas mileage considerations.
The one that’s really bad has a damaged retainer cup that the center bolt bolts to do it doesn’t seat perfectly on the wheel. I have to get a “new” one, but I’ve been hesitant to get one from eBay. I think I’ll check today, though.
idahovette
Weiser Idaho
Perry
K20-K10
I bet it's hard to find a good one , probably gonna come off the driver side, the passenger side always got beat up by the curb. LOL
Kinda is. For a little brass cup, people sure want a lot of money for them. That is when they’re actually available online.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Just like a delay wiper switch for a 78 square, $50+
datto62073
Monroe
Mark
reading this thread makes me want to get my 86 wagon going. 2 tone blue, 307 OLDS, 2004-R, 225k. runs great but needs an AC compressor, and a rear diff. its so much cush.
That doesn’t sound bad. If I had a wagon, that’d be perfect. The sedan’s good with cargo, but the wagon would be just right for what I do and need. You should get it going!
datto62073
Monroe
Mark
soon enough. after i get the property setup, that'll be one of the first to be done.
Ole reliable being reliable as always. I’ve had a few lightbulbs go off in my head of mods that I’ve started to do/I’d like to do.
1. Get my damn aux. cluster built and installed:
I’m not gonna replicate the 9C1 location because I don’t want to mutiliate the dash and have to move things around which means mutiliating the dash even more. I need to tap into my dash lighting circuit, and I’d like to have easy access to my instrument harness to tap into the idiot light wires or to the firewall for organic wiring.
I’m thinking I can use the ash tray as a mount (already made a template for the enclosure pieces), use the ashtray light wiring for my two instrument bulbs, and still have use of the ashtray for storage. It would have to have holes drilled in it for wires to pass through and flush screws for the mounting, but an ash tray is smaller and vastly more replaceable than a dash panel.
My only issues are will the ashtray want to partially slide out after becoming front-heavy, and what is the most reasonable material. I like ABS plastic, but it’s to thin for screws to go in so is wood the best alternative... I could always mount in the actual hole, but I like the idea of having part of the work done for me.
2. Sequential turn signals/brake lights:
The mod speaks for itself. I’m assuming the turn signal motor that old Mercs had was kind of like a breaker point thingy that would be difficult to replicate and probably too primitive to be reliable. The easiest way would probably to tee into the rear harness as it passes through the trunk into the rear cap. I’d be open to building my own, but I don’t really know where to start.
3. I want a spotlight:
I think they look pretty badass. Need I say more?
4. Dog Dish caps (maybe)
Overall, I think it’ll transition to something resembling a 9C1, but I’m hesitant on the wheels. I like the spokes, and I may end up sticking with them for the long haul. We’ll see.
southbaymiller
