SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
Now that I've driven the truck a few weeks without the Detroit locker there is NO WAY its going back in. I am going to purchase a Limited Slip Posi and install it myself. I've gone back and forth on keeping the SF axle in it and swapping the gears to 4:56 to match the front...or...keep the FF and swap the carrier and retaining the humongous brake drums (13 x 3.5) and weight of the axle. All in all, I think keeping the FF and just adding the posi is the most cost effective option.
With that said: Can I install a new carrier and reuse the existing ring & pinion gears? I believe the setup on the FF is fairly easy, since it doesn't use crush sleeves or side shims. Getting the gear pattern back to "stock" should be achievable, I think?
What say yall?
What say yall?
