Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
I'd check O2 sensors (if they Exist) for Lean condition.
And Fuel pressure (you are looking for 12 psi MIN)
You cannot tell if injectors are putting out 12pounds, you can only tell if they're clogged. You Want a super fine conical shaped mist.
I've learned even if it's a nice mist pattern, that still doesn't mean 12 pounds of fuel pressure.
Video kinda sounds like a misfire which is either bad plugs, cracked plug wires, poorly set timing, or you have corroded tower inside the distributor cap (maybe more)
