Need to replace rubber fuel lines on top of both tanks….
Dukester68
Gary
c2500
Thank you all for the help!! I now have to figure out my gauge issue. I will put that post up soon
75BEASTK20
B.C. CANADA
Cal
AND YES......it's definitely a good time to replace your one set of body bushing mounts.
Auburn, Washington
Hi! All bed bolts were like new condition so i guess i got lucky. I was able to move the bed back enough to work on the sender units, new fuel lines. Thank you for your help!
Nice! Now you got all the rules belt guys jealous…
Rust belt,but I got it,and yea, very jealous. No way are you getting the rear cab bolts and all the bed bolts out of a Kansas truck without a drill and a torch.
75BEASTK20
B.C. CANADA
Cal
I had to measure and cut a little steel to fold back, to access the middle cab mount bolts. It has a caged nut in size and they are almost 100% fu**ed, and just sit there an spin. Use plenty of "Break Away" or "PB blaster" or any spray lubricant and work the bolt backwards and forwards and eventually it will come out. You will use quite a bit of "PB Blaster I can be a pain the ass but it can be done. Just go easy on the cut off wheel. There are some VERY good videos on you tube if you search square body cab mount replacement. I hope this all works out for you! Make sure you save the bolt and clean it up really good with wire brush. A lot of guys have done it, and it makes a noticeable improvement. I had yet another 1975 that was SO rusted, the cab supports literally fell off on the highway from rust. You do NOT want to get to that point. It is probably one the #1 rust areas in the entire truck. GM flaw design
Cal
Dukester68
Gary
c2500
Ha ha yes.. this truck was a pampered California truck. I was shocked to find the condition it was in after i buffed through the thick layer of oxidation. Honestly though all the bolts came out without any issues.
Long Rider
La Grande Oregon
I installed a new take and lines without removing the bed on the truck I have now. My first square, the red one in my profile picture, I did with the bed off. I had the bed off anyway to do some work on it. If you replace the lines that you can see between the cab and the front of the bed like in did on my last tank swap, I found that the new rubber gas lines kinked when I lifted the new tank into place. I finally used some 5/8 inch inside diameter garden hose over the top of my gas line from the top of the tank to the hard line inside the frame. That made it stiff enough not to kink and gave it some added protection.
nbrizjr
