Need to replace rubber fuel lines on top of both tanks….
Long Rider
La Grande Oregon
The original rubber fuel lines from the tank to the hard lines were a lot heavier than anything I could find when I installed a new tank and sending unit. In order to protect the new lines I put some old garden hose over the new rubber gas line. Cost almost nothing (clamps) and works great.
jwroblesk
minnesota
Joe
c 20
Hey Gary, What rig did you get from Summit to assist you with Bed removal? Joe
MJJN
Washington, MI
Here are some pics (1982 C20) of what things look like if you decide to dop the tank.
Dixie Pride
Southern MD.
Al
1985 K20 had since new.While i had the bed off i replaced my dual tanks and soft and hard hoses.Bed bolts can be hard to get off they are more like a carrage bolt.Tank strap bolts can be tought too.I did float replaement while i had the tanks out.Sometimes the easest jub can be a bitch.Dual tanks are different size on my truck than single tanks.Hard part was finding the medal filler tube,i ended up making my own buying pre bent SS pipe.Put rubber tex on the bottom of tanks too. Hard to find tanks as thick as the original.I did it anybody can do it.My truck is Labeled REVERENT BLACK .3" body lift ,4" rear & 5" front suspension lift with cut-out fender flairs and 44" Mudders.I am still a kid at 67
Dixie Pride
Southern MD.
Al
1985 K20 I forgot i used my tractor with a log boom and 4 straps to take the bed of and back on it was a little trickey but made it work, dont forget to unhook the electric, taillight brake line clips .
Dropping tanks don't eff with the tank straps. Unbolt the the tank brackets from the frame. Tank straps are a bit#h and 1/2 the time break, bed bolts,again usually a PITA, tank brackets un bolt easy because of where they are,and that the bolts are short and in capture nuts,they don't have the same rust problem as bed bolts and tank straps.
tman
Stockton California
Tim
K1500
I just wanted to say that if you take a Dcell battery and connect it to the fuel gauge the level should go to 1/2 tank , that will show if the gauge is working.
75BEASTK20
B.C. CANADA
Cal
Loosely cover tank(s) with a wet blanket underneath, to avoid sparks hitting any tanks after pumping out as much fuel as possible. Disconnect hose(s) from filler tube(s) with zip cutter (WEAR PPE GLOVES AND GOGGLES) Plasma cut the bolts from underneath. This should take approximately 6 seconds. Hammer whats left of the bolt through the holes from the bottom. Hook old bed to Cummins in 4-LO and let 'er rip. Make sure there is nothing in front or beside ANY trucks. That's if you DON'T want to save anything on the bed. Mine was entirely rusted trash - hence the Cummins approach. Or you can use a bed lifter $$$ and drive the truck away from the box. Quite boring and mundane approach in my opinion. I've done both ways. Cummins yank off is much MUCH more fun. Stand safely away from area. :) The neighbors will be watching the 'show' closely..........sipping a cold beverage. Get your neighbor to carefully set down his cool beverage (as not to spill any) and ask nicely for him to lift the bed off the ground with his tow truck and place mangled bed onto the Cummins bed with 2x4's or bigger underneath, to avoid scratching your Cummins bed. We don't want any unneccesary damage to occur.:) Strap down securely. Drive safely to the dump. Resume sipping cold beverages. Remain calm.
heavymoneyhuff
