Need Rear Drum Brake Assembly Diagram for a 1976 K10
Allallon
Max
Hello everyone!
This is my first post so I hope I am doing it correctly. I am fixing up my first Squarebody, a 1976 K10, and my rear brakes are not working correctly. The rear left seems to work fine and bled them, but the right rear I cannot get to bleed at all. I copied the assembly from the left rear breaks that work, but when I put everything back I have no brakes.
I was wondering if anyone could provide me with a diagram or point me in the right direction to find one on the internet on where everything is supposed to go on the rear drum breaks so I can redo them and see if I can get them working.
Thank you and if more clarification is needed please let me know.
fast 99
Spokane, Washington
Assume no fluid during bleed? Plugged bleeder, dirt inside cylinder, crushed line. If the left is bleeding the problem is from the T on the axle to right brakes. Shoe and hardware assembly shouldn't affect bleeding.
Ryanmikeb85
