Need info on fuel lines and pump to convert dual tank carb to TPI on 85 K10
MSCHWEGS
Minnesota
V10 K10
any info on parts and things to watch out for would be great!
8T6K5
AZ
L98 350 TPI
Just re-did some fuel lines on my TPI.
Used Fragola SS PTFE hose and fittings. Just make sure you get teh right fittings for the hose you are buying.
Hose size should be -6AN
MSCHWEGS
Minnesota
V10 K10
what did you use for a pump? that the type of hose you used from the tank to the TPI?
8T6K5
AZ
L98 350 TPI
I didnt do the original swap...just cleaning up after them.
MSCHWEGS
Minnesota
V10 K10
thanks for the lead its a start!
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Use SAE J30r9 hose for fuel injection. available at any good parts store. for the dual tanks, you can use an 87 selector setup that will switch the pumps and gauge senders. I would recommend using inline pumps for ease of maintenance.
kaydenfeathers
