iflyfisher
- Oct 22, 2023
- So Utah
- Ken
- K20
I'm replacing the cab mounts on my 1973 K20 and have finished up the front cab mounts. I pulled the bolt on one of the rear mounts and saw that I will need to lift the corner by about 3" to remove the metal sleeve. I had read to replace only one corner at a time to not shift the alignment. But lifting that one corner 3" with the other corners still buttoned down seems like a lot. For those of you who have done this, should I pull the other rear mount bolt before jacking up the rear cab corner or is jacking up one corner 3" not an issue? Thanks
Ken
Ken
