Need help with regards rear ac
Ohearchai
Washington
Martin
V1500 Suburban
Decided to do my headliner, as the vehicle isn't my daily driver this was a long time project with a vacation in between. Well I went to put the rear panel in and I realized that something was missing. The hose with the clip about 4 inches down was attached to something and I have no idea, there doesn't appear to be any other hoses attachments around or on the rear unit itself.
Rustisbest
Tennessee
6.1762844 liters
Looks like heater hose to me. Bet the heater core started leaking and it was unhooked?
gmbellew
Kansas city
glen
suburban 1500
I've not had the passenger side panel fully off, only dropped the AC panel to replace the TXV and clean the rear fan. but I know the drain for the rear system goes through that area. could it be that?
Ohearchai
Washington
Martin
V1500 Suburban
Guys thanks for the replies and the further I Look ad dd1990 states it's the drain hose, unfortunately I have no idea what it connects to or if I accidentally tossed the fitting. Are the holes in the corners the drain vents?
dd1990
Ventura CA
Suburban 1500
Do you still have the shroud that covers the rear ac, the tube just slips onto the passenger side corner of the shroud, you should see a round protrusion on the corner of the shroud
Your whole cover is missing dude.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
It connects to the plastic cover that I guess you are missing. That whole large mostly trapezoidal "decorative" cover that bolts with 3 screws at the back and couple of metals screws up front It doubles as a drip pan. Condensate drips on a plastic cover and them drains to the right side and down this tube.
Ohearchai
Washington
Martin
V1500 Suburban
Well I suppose if I wasn't a dumb ass I might have figured
it out, thanks for all the help guys.
Looked at my shroud and you there's the pipe.
MattsC10
