da_raabi
Trailer Park Supervisor
- Aug 7, 2013
- FloriDUH
- Adam
- c30
I didn't notice that a clutch was installed. Fan does look too close to the engine. It should be just inside the shroud.
No clutch on fan
I meant that there should be a clutch there. I wonder if that's the problem? Maybe the PO had a problem with the clutch, and instead of replacing it they just removed it? That would pull the fan backwards a good bit, resulting in the problem at hand.
A nice new HD clutch will benefit you in two ways: 1. It will fix your cooling problem and 2. It will likely free up some power as the fan will only turn when needed. I'd definitely look into it!
