Need help with 5.3 ls swap
Camar068
Kentucky
10 yrs Air Force
throttle out
Michigan
Sam
5.3 LS
Alrighty so i'm going to put in an order for fuel parts and this is whta I have so far:
1987 R10 Fuel Tank
1987 Fuel sending unit
Walboro 255 gss342 fuel pump
3/8 to -6AN QD is Russell 644123 (feed)
5/16 to -6AN QD is Russell 640863 (return)
Fragola Hose assemble AT165056ERL (hardline to rail feed)
TBI truck fuel filter(dont have PN yet, if anyone would suggest one)
2 of the AT991955ERL fittings to adapt it from 16mm o-ring to -AN
And I believe my truck doesn't have a return line but I'll check tonight.
Again, Thanks a lot everyone!
Heres what my list looked like.
#'s 1 & 2 look good on your list, my truck was an 87 so I already had them.
#3- AC Delco EP381
#4- 3/8 compression to -6an (SU feed)
#5- 5/16 compression to -6an (SU return)
#6- 20' of 3/8 (-6) stainless fuel line
#7- 3/8 gm quick disconnect to -6an fitting (ls fuel rail supply)
#8- 5/16 gm quick disconnect to -6an fitting (ls fuel rail return)
#9- 6, -6an straight fittings
#10 inline high pressure fuel filter
You want an AC Delco EP381 for a fuel pump, not the walboro you have listed. These can be had for $25 or so. Is what I used and WILL mount up to your sending unit like factory.
Better off in the long run to convert to AN fuel lines.
firzty
