Need Help Wiring Chevy Distributor
Lanse
Fort Worth, TX
Lanse
So, what I've done (this time haha) is remove the entire powertrain from an 81 chebby have ton and dropped it into a 1948 Farmall H, by means of custom fabri-cobbled frame rails and one of a kind drive shaft.
Since obviously theres no computer with this, I've done the ESC to HEI distributor conversion by mutilating some wires as pictured.
Today I tried to get this thing started and couldn't get any juice to come out of the plugs, so i'm thinking that I must've done something wrong here. Anyone ever rig up a distributor like this here? I sawed off the distributor vacuum module thing when I was removing un-necessary stuff from the engine, now I'm starting to wonder exactly how unnecessary it was.
Anyway, I'd really like to get this thing going so it anyone has any pointers I'd appreciate it. Thanks guys!
Georgeb
Wisconsin
George
K10 Burb Z71
That should have been a one wire connection. The wires with the nuts were for the control module which you needed to get the coil to fire and the vacuum advance was an easy single vacuum hose to the manifold. You just needed a power wire to the bat terminal on the distributer. Time for a different distributer.
hatzie
k20
Those are the correct connections to kill the ESC. Will it run like that. It should. You can modify the mechanical advance with weights and springs to make up for the lack of vacuum advance.
If you have module issues I'd recommend getting a new AC Delco Professional 4 terminal HEI module and a new 4 terminal module to coil harness to replace the 7 terminal ESC HEI module.
Some interesting reading. No you don't need a vacuum can. You will have to re-curve your advance a bit. After dumping the smallblock in a tractor that's small change.
superchevy.com 10 Common HEI Myths
Georgeb
Wisconsin
George
K10 Burb Z71
Wow, i really blew it on this one! Sorry for the miss information. I had to go back for a closer look and see that the pic with the wire nuts is in fact the esc wires. I thought they were the wires for the ignition module.
Sorry for not looking closer.
GorillaHumper
