Is there a question in there somewhere? What is the problem? What are you trying to do? It's an 87, so first year TBI... do you have a check engine light on? Is it running poorly? When you short the pins on the ALDL connection it should flash any active codes. It should be steady flashes, followed by a short break and then more short flashes. Then a longer pause to show that you have a second code starting. So if your codes are 22 and 37, you will have two flashes.. pause.. two flashes... longer pause... then three flashes.. pause... seven flashes... longer pause.. then back to the two flashes..etc.
There is a reference library sub forum on here that has all of the manuals. If you go to the 87 manuals, you can open up the emissions and drivability manual, which will have troubleshooting flowcharts and instructions for all of the codes.
