- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
well if you prefer something a bit more attainable,Thank Taylor, Pretty much I've put everything on hold, bedliner, interior carpet ect all on hold. IDK, if you have seen the thread but my transmission is going out now. Short version is there is bearing noise coming from the 1st / reverse shaft. I'm still driving it and using it, but want to get it rebuilt in the next month or two so it does not go out and leave me on the side of the road with a bed full of feed.
I also occasionally slide loaded pallets in and out of the truck. I can't tell you how hard that can be with that stupid spray on bedliner. I'm sure I've torn it up doing that too. Well if a cheap enough used bedliner comes along I'll grab it anyway even though I'm trying to shut down any unneeded expenses so I can do this tranny.
Plywood, preferably the thick and nice surfaced stuff(Used for floors or maybe something else IDRK) its heavy and has a consistent surface vs a normal plywood look. Even if it was cheaper plywood.
4x8 sheet lays down in the bed nice, secure it, and either coat it in something slick durable or just use it as is and it will do a lot for you that way even.
