Mystery wires dangling on Mystery Vac Hose
BBBURB
Anaheim, CA
Zeke
R2500 Suburban SLS
454 7.4L
Hi guys Im a newb and just trying to figure out where these suckers go.
Do I even need these? Seems after the TBI kit rebuild and new injectors Im running a lot better. I want to throw down some timing on this mother but Im worried about these hanger-ons. What are they?
If anyone could help identify these suckers or post a diagram for me it'd much appreciated!
Thanks yall!
This is a 454 TBI 7.4L
#1 Wire end has been cut off by a monkey obviously and wrapped in electrical tape!
BBBURB
Anaheim, CA
Zeke
R2500 Suburban SLS
454 7.4L
Nice job with the outlines, Slick.
That looks like a really great, pic. :waytogo:
Thank you Rusty, I made it photoshop cc. Took me about 15 minutes. I work with photoshop professionally for many years. Might take an inexperienced user much longer unfortunately.
BBBURB
Anaheim, CA
Zeke
R2500 Suburban SLS
454 7.4L
350 w/203
Before I get too excited, let me know if that helps you any.
BBBURB
Anaheim, CA
Zeke
R2500 Suburban SLS
454 7.4L
I converted those electrical wiring diagrams into a more user friendly pdf file. Now im going to take a deeper look.... Thank you! Will reply back in a moment....
Link to Wiring Diagram in pdf: https://drive.google.com/file/d/1c1J4-rEokxIAuhE103kFF1xWG3qpXjni/view?usp=sharing
Ok so I was able to identify this:
#3 is a tachometer wire which I do not have a tachometer so it would make sense that the wire is not connected to anything. This wire is coming from the coil.
350 w/203
#5 looks like a check valve feed for the cruise control. Maybe to the brake?
#6 looks like a PCV hose. That would go to the air cleaner.
I don't know about the #2 wire from the gray relay. I think the black relay next to it is for the fuel pump or, if you have 2 fuel tanks, the tank switch relay.
I'm guessing #2 is the test wire for the fuel pump.
350 w/203
DAMMIT bucket!
You didn't tell me there was going to be a test?!
BBBURB
Anaheim, CA
Zeke
R2500 Suburban SLS
454 7.4L
Well after much research I have come to the conclusion that these dingleberry wires are simply there for entertainment and serve no real purpose other than a practical joke at my expense. Thank you all for your help. Let me know if anyone wants some photoshop done!
BBBURB
Anaheim, CA
Zeke
R2500 Suburban SLS
454 7.4L
Here is what I have so far...
  1. unkown
  2. test wire for fuel pump
  3. tachometer wire
  4. unkown
  5. check valve feed for the cruise control? Maybe to the brake?
  6. plastic pcv hose to air cleaner(changed mine for a rubber hose and a plastic elbow)
As for #1 and #4, green wires of that size and connector style are usually A/C related.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
+1. Just checked mine and it's not connected to anything.
For #5 it's a bit complicated but this should help.
So hose 3 terminates at the manifold between the egr and dizzy. Hose 4 goes to the vacuum reservoir. Hose 5 reduces in size just after the junction and goes through the firewall near the ac box.
Your first two pictures show the mystery green wire plugged in. Where does it go to on your truck?
DollarBill
