Mystery Tachometer
ButchM
Idaho
Butch
Hi everyone, after a ridiculous amount of online research and coming up with absolutely nothing I decided to join a forum and hope that someone else has seen this gauge before. So I'm in the process of "restoring" my 1986 Chevy K10 Scottsdale, after 8 long years I've finally found the time to install the engine I rebuilt 5 years ago and the transmission I rebuilt 2 years ago. The truck now runs and drives and to my surprise all of the factory gauges actually work, they just needed to be hooked up to sending units. I've got the voltmeter, temp, oil pressure, clock, and fuel gauge working and I have my eye on the factory tach now.
This tachometer has the fuel gauge built into it, I can't find anything about this gauge anywhere, it's like it doesn't exist. Every gauge cluster I've ever seen either has the large fuel gauge next to the speedometer or they have a single tachometer and a small fuel gauge where the clock is. I haven't actually pulled the cluster yet to see how the tach is wired, for now I'm just super curious as to where this gauge came from.
Also, this truck has the body of a 1986 C10 and the frame/drivetrain of a 1975 K10 but these gauges look like the 1980s style to me.
(sorry for the crappy pictures, it's a pretty sunny day)
Pete
You have a hybrid/Frankendash. The clock is an option (don't have the option code) for "regular" pickups (C/K10-30). The tach you have is from a C50/C60 series medium duty truck with a 366 or 427 engine with air brakes. On those trucks there was an air pressure gauge where your clock is. The 5000 rpm top end is a clue, those engines had a much lower redline due to the heavier piston weight.
I have one of those tachs I plan to install in my truck.
As a side note: I was told by an old Chevy mechanic that the trucks that came from the factory with an air compressor (all air brake trucks) had forged steel crankshafts. May be a good source for that forged 427 crank at a cheap price.
Butch
frickenbored
Michigan
Pete
Scottsdale K10
5.7L
Pete
Butch
Yeah, this doesn't surprise me. The whole truck is Frankensteind together by the previous owner, now I'm doing my best to un-Frankenstein it. Hopefully I can pull the cluster this weekend and find out how that tach hooks up; however, I'm doubting it will play nice with my MSD 6AL box, but I should at least see it do something. I plan to ditch the MSD ignition soon in favor of a Progression Ignition digitally programmable HEI distributor anyway.
Redfish
Prairieville, LA
Andrew
V1500
I got mine from LMC with a new pod and printed circuit. All works great. I had to cut a bit of the speedo hole with a unibit.
This conversion is on The List. I just hate to give up my awesome Quartz Clock! I remember GM advertising being really proud of that Quartz Clock.
If the tach still works, it should work with the 6AL just fine. The tach should have 3 terminals. One ignition 12+, one ground and one tach signal. The 6AL should have a tach output.
Keith Seymore
Motor City
Keith Seymore
4.3L
This is basically what my '87 came with (no trip odo).
Clock was in the radio.
K
nvrenuf
Mobile, Al.
This ^^
I ran a factory tach with a 6AL in my old K10 for years, worked great.
1975 GMC suburban
