My Rear End Build For My Low Buck Street/Race Truck
Mark Jones
Horse Shoe Bay Tx/Thousand Oaks Ca
Mark
I've posted on here before about my 79 C-10 long bed with a 3.07 open rear end. Running a best of 13.50 @ high altitude tracks, now its time to turn it up. Locally the last time I had the truck out I had a wheel spin problem actually because they don't want to prep the track, and with the open rear end I need a decent track not to spin. So I'am planning a series of modifications, 1. I will build a truck 12 bolt with 5.13 gears, I will post pictures of the 12 bolt build as I go. 2. I will replace the 2 piece drive shaft with a one piece aluminum shaft. 3. I will re drill the front brake rotors so I can install a light weight race rim/tire combination, at the same time the steel rear rallye rims will be replaced with light weight race rims.
CoggedBelt75
Oklahoma
Joe
Just a few questions to understand. Driver or building for track? 1/8 or 1/4? Assuming 1/8. You say wheel spin, street tires or slicks. Assuming street. 5.13’s will get you started but need ponies to finish it off. They would be fun on the street tho.
That's steep gearing if the street will be involved much. How tall of a rear tire?
Mark Jones
Mark
I run slicks, 1/4 mile drag racing. I also drive the truck on the street and to the track, I will be limited to 55 MPH down the hi way with the 5.13 gears.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Hey Mark, that is fast for a big ol' square, way to go! What are you running for an engine tranny, just curious. I too like to go fast, and thrash my stuff, and just swapped in a slightly modified 454, still running the 350.
Mark Jones
Mark
I have a 327 in there with a Turbo 350 trans.
Mark Jones
Mark
Some pictures of my progress on the rear end build.
potent rodent
indiana
butch
86 and 78
350 and 305
u better have the engine to go with the 514 gears. they are not street gears nor are they 1/4 mile gears they are 1/8th mile , u said u want to run 55 mph on the hwy like i said u better have the engine or that 327 will have a short life
idahovette
Weiser Idaho
Perry
K20-K10
I had 5.13's in a 56 Chev 2 door wagon that went 12.50's 1/4 mile at Firebird Raceway in Boise Idaho, back in the late 60s early 70s. Then I went to 5.57's and could NOT hardly shift fast enough(4 spd muncie). Was FUN, though!!! Never did run out of engine, all on GM parts, except for the tunnel ram(Edelbrock). Bought GM stuff cause I worked at a dealership, couldn't afford the aftermarket prices.
CoggedBelt75
Oklahoma
Joe
Do you happen to have any pics of the wagon? I realize back then cameras were never handy. I never owned one until later in the 80s.
cland13
Marvin
350 w/ corvette 113 aluminum heads
I think you would be better served with 4:30 gears as you will still get the launch you need and will be better on the street. I ran an s10 with 383 / 400 4:30 gears and
14-32 slicks, constantly was in low 10's
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I'm not a racing person, but it seems like for a 30x9 tire, 5.13 will leave you running the dog **** out a 327 with a th350 with not much top speed... Seems like 4.10-4.56 would be a better choice? Maybe more towards 4.56 so you still have a good takeoff and top end?
Again, I know nothing about racing, just 4x4.
2manysquares2care
