77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
So in 1988 or so my dad bought his GMC truck from the original owner who was a mechanic- it was in great shape and had a 400 small block in it. For the next 17 years or so it towed his small 18' 5th wheel with the greatest of ease. Then the motor got tired. I told him to rebuild it. He heard of the famous 400 overheating issue and I guess that scared him off from doing it.
So he decided on getting the Chevrolet Perfomance 350- the 290hp version:
Specifications:
Horsepower: 290 @ 5100 RPM
Torque: 326 ft/lbs @ 3750 RPM
Max Rec. RPM: 5100 RPM
Compression Ratio: 8.0:1
Heads: Cast Iron 76 cc Chamber - 1.94 Intake valve/1.5 Exhaust valve
Camshaft Lift: .450 Intake /.460 Exhaust
Flat Tappet Duration @ .050" (222°Int/222° Exh
Lifters: Flat Tappet
Connecting Rods: Powdered Metal
Block: 4-bolt main
Pistons & Pins: Aluminum
Crankshaft: Cast Iron Nodular, 3.480" Stroke
Rocker Arm: 1.5
Ignition Timing: 34° BTDC total advance
Fuel: 87 octane
It doesn't tow his trailer worth anything. So he then has the dealer install a Edelbrock performer 2102 camshaft to go with his performer intake manifold.
Helps out some- but still not acceptable. Then someone notices that his RPM is pretty low at 65 mph. Find out his has 3.08 gears. I tell him to get 4.10s since he only tows. He has 3.73s installed in both axles. It is a bit better- but still not good for hills. (tires are only 235/75R15s)
He now has a lot of extra money dumped into this and still wants it fixed. The next thought he has is this winter putting some different heads on it (possibly vortec heads) and then ditching the factory exhaust manifolds and going with headers. This will help also- but don't think it will be a "fix".
Is the edelbrock cam to mild to use for towing?
duration @ .050: intake 204* exhaust 214*
lift @ valve: intake .420 exhaust .442
lobe seperation 112*
Specifications:
Block: 4-bolt main
Rocker Arm: 1.5
Fuel: 87 octane
