- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
oh. so im missing a spring. Is the purpose of that holding the pivot pin to the fork to make the feel or behavior consistent and then of course the big one being for the overall engagement being held off unless you push. right? I could be wrong@AuroraGirl I don't need a replacement, I was talking about the push rod from the pedal to the z bar. The two lower springs one holds the pivot pin to the clutch fork and the other pulls and holds the clutch fork away from the clutch when your not shifting. There should be two one small one and one long one going to the frame.
