motor mount question
hiltijoe
ny
joe
custom delux
will the motor mounts work from 350 to a 454?
gpmorgan
Tupelo Ms.
greg
Yes, mine did.
yevgenievich
Place
Name
Year
Model
Size
big block mounts are taller, but small block stands work
gpmorgan
Tupelo Ms.
greg
The mounting pads on the block are further back on the big block. The big block will sit higher and toward the front more.
hiltijoe
ny
joe
custom delux
I don't think id what the bb mounts because of header clearance?? any idea what the part number is for the bb
gpmorgan
Tupelo Ms.
greg
Don't know #. I used the small block mounts from the block and put them on the bb. The stands on the frame are the same also. I ordered headers for my truck and they fit correctly. I used Headman Elite headers.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Actually the mounting surfaces on a big block are in the exact same spot as a small block proportionally to the trans mounting surface. As in if a small block bolts in so will a big block. It's whether it fits with the added height, width and longer block after the mount surface forward but mount to trans is the same and so is pad heights and width. I have small block solids on my big block in an 87 v10 and no changes to the frame mounts direct bolt in.
gpmorgan
Tupelo Ms.
greg
Yes direct bolt in. I was referring to the front of block but you're right, same spot in relation to trans.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yup quite a bit of over hang I did have to notch my cross member to clear the oil pan. Which means no pulling the pan off without jacking the engine up. Was kinda pissed about that....oh well it is what it is.
gpmorgan
Tupelo Ms.
greg
I've had these 3 engines. Black one is the weak 5.7 tbi. The one on the ground is a 450hp 355 that I built. The big block is a 632 blueprint pro series crate engine. I've used the same mounts on all except for changing them to polyurethane.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Chevy had some thinkers back then didn't they? lol I'm sure it was just cheaper lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
And that tall deck is well taller and wider.
danrw2008
