- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
But when the speeds are exponentially wrong, i.e. 2 mph at 30mph, 5 mph at 55 mph, 10 at 70, he would best benefit from getting the right gears for his speedo.
Tires are 33-12.50-15 Gears are 3.08s front and rear Trans is a TH400 Transfer case is an NP203 I would really rather do it the right way and never have to worry about it again. The PO did so many half ass things to this truck that have bit me in the ass already. I'm with Mike Holmes: "Do it Right!" No offense Burb, if it weren't so far off i probably would just move the needle. At least my cheat sheet got a laugh out of the guy who pulled me over.
Exactly. By moving the needle you are just splittin the lie. Instead of being off by 10 at 50 mph, now its accurate at 50, but then reading slow up to the 50mph, then past 50mph, its starts reading to fast again. It woudl never be accurate, just compensated for and off a little less. Its all mathematical. For purpose of making it easy, lets say you are off 5mph at 25mph, then 10mph off at 50, 15mph off at 75, the of course 20mph off at 100.
So your tire size make this one easy, we don't have to convert the tire size ti figure your height. You height is already given and its 33. Trans isn't going to matter cuz the Tcase is what will read the speed, so we need gears for a NP203 speedo driver, and gear ratio of 3.08 in the rear. I'll get busy looking for the info.
