75Monza
- May 5, 2017
- Colville, Washington
- Jeremy
- 1980, 1982, 1985
- K30, K20, K20
Figured I have so much stuff in the fire, just as well do a thread for them too, lol.
So, going to start this one out with my most recent tow home from yesterday. I had thought I knew everything about this truck since it hadn't changed since I first remember it when I was 5, but after much discussion with 2 of my uncles, nobody is really sure about what I'm dealing with. On the title it lists it as a 1963 Chevy pickup, no other info or weight data. The only emblem or scrip indication on it is the Chevrolet tailgate, chevy emblem tail light lenses ...fender badges are gone. The cab is a 63 for sure since 64 got rid of the wrap front windshield. The front suspension seems to be a 63 3/4 since it is coil spring and 8 lug not set out like a dually...62 used a torsion arm instead of coil spring. From appearances, looks like a 283, although it could be a 327 . 4 speed is a syncro 4 speed with the parking brake drum on the end, was in several years so not a good indicator.
Here is where things get weird...wheel base and rear axle. It has a wheel base of 133" and rear leaf with aux overloads. The 3/4 ton seems to have been coils in the rear, leaf was for 1 ton. There are 3 possibilities, they were offered as a 9' step side, a cab and chassis, and a stake bed in that wheel base. I could have swore that it was a flat bed originally but one of my uncles thought the flat bed was a GMC truck, not the Chevy while my other uncle thought it was never a flat bed and had the fleet side bed. Then, we found old pictures of grandma's that showed it as both, yet flat bed was green instead of white. Scratched front valance on the truck and sure enough, it's glenwood green under the white.
Not sure of the gears, but remember that they were really low, so most likely 5.14:1 since that was what the 1 tons had.
The box... after looking close at welds inside the bed that I thought were from damage from when he had the camper in it and plopped it on it's side, we figured out the bed is sectioned 7" so that it's 8'7" inside to match the wheelwells and cab gap...so much for my idea of buying new bed sides, lol. Have to resort to fixing ancient bondo work.
