AlexK10
- Nov 26, 2018
- Puerto Rico
- Alex
- K10 Long Bed
Hi everyone, About 8-10 months ago I tore down the top end (removed intake and heads) to fix a head gasket leak in cyl #8. This cylinder had water when I pulled the spark plug to do basic maintenance and led me to remove the heads etc.
Anyways after getting valves reseated (new stem seals) and flattening the heads at the machine shop, I got new gaskets and reinstalled the heads and continued with all the extra work involved
Details of what I did and used:
Head surface and valve job
Fel pro 8510 pt head gaskets
Visually checked the block surface and cleaned with solvent rag
Used thread sealer on all head bolts
Torqued in 3 step process following the correct sequence
Fel pro 90314-1 intake gaskets with black Permatex on front and back china and around water ports
Thread sealer on all intake bolts although 4 don't go into water or oil passages.
On initial startup I noticed bubbling between the intake and the head surface. So I timed the engine at 12BTDC tuned the carb (over several days). Noticed condensation on the oil cap and lots of water droplets on the dipstick.
Removed the intake and used:
Mr. Gasket 8520 intake seals that have a silicone ring around each port
Used the right stuff around all ports (not only water ports) and also on front and back.
All start ups have been great, meaning No bubbling between intake and heads as before and no droplets on the dipstick.
To flush the water that had leaked into the oil from the original intake leak... Did two oil changes to flush out any water or condensation. The first one with a diesel flush (added a quart of diesel to the oil in the crank, ran for 5 minutes and drained). Added new oil and filter, ran for 10 minutes and drained. Then added new oil and filter and that's what it has now.
However, my oil is slowly getting milkier and oil cap always has condensation. Which leads me to believe I still have a leak, and coolant is also slowly dropping.
Extra info:
No oil in coolant
No visible bubbling in radiator
Engine temp between 180 and 200
Timing at 12BTDC
Starts and shuts down without issue
New PCV valve connected to lower vacuum port on quadrajet and new breather filter on the other valve cover.
Stock 305 other that bored cylinders. Not a performance or high HP engine.
When I removed the heads the first time I noticed either a .30 or .40 stamped on the top of the pistons. Will check photos to confirm.
Getting ready to remove the heads again and have them checked at the machine shop for flatness.
The question:
If my block was bored to .30 or .40, what head gasket is best? Any part number recommended?
Was thinking of using the Fel pro 17020 head gasket (instead of the 8510 pt) but not sure if it would seal correctly with oversized cylinders.
Any other ideas?
Extra info:
No oil in coolant
Timing at 12BTDC
The question:
Any other ideas?
