burb1085
- May 23, 2015
- Lancaster
- shawn
- c10
Curious to know what driveshaft length you've used. Have a 454 th400 10 bolt swb 2wd . The engine and trans were swapped in a 79 C10 truck that originally had 350/th350 combo. The th400 had a bolt on yoke, so I ordered the conversion slip yoke from Denny's DriveShaft. I'm trying to use the original th350 driveshaft and just have it lengthened. From the end of the th400 output shaft housing to the center of the pinion yoke, I have 61 inches. I think with the slip yoke I'm supposed to add another 3/4 to 1 inch. Am I doing this measurement correctly? Does anybody else have experience with this and know the length of the one piece shaft? Thanks for your input.
http://www.dennysdriveshaft.com/p15...5_transmission_slip_yoke_for_use_o.html#photo
