charlie phillips
- Jul 25, 2020
- pennsylvania
- charlie
- c10
I have a '76 Cheyenne short bed 2wd 350/auto. Disc front and drum rear. Manual brakes. Problem I'm having is the new master cylinder bench bled great but when I put it on the pedal goes to the floor and I have to pull it up. Is there a return spring of some sort for the pedal? I thought the pressure from the master cylinder would keep the pedal returned. I've replaced everything in the brake system. Shoes, wheel cylinders, hardware, pads, all new lines, new proportioning valve, etc. Any help is appreciated.
