ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
So, the truck is getting ready to go back together and back on the ground.
I have a Cold Case aftermarket aluminum radiator, and concerned about over tightening the inverted flares into the bungs for the cooler lines- soft aluminum obviously.
I know the flare does the job for the seal, but since I know I can’t really tighten the fittings TOO tight without the aluminum threads getting tired, is there any suggestions for something to put on the threads, if nothing else than for vibration resistance? I was thinking a small amount of Ultra Black or Ultra Grey RTV that would help with both vibration and provide a small measure of resistance to weeping. Or for that matter, maybe a small amount of blue 242 Loctite? Thought I would ask here before I finalize everything and fire it up today. Thanks in advance.
Edit- even if you don’t have an answer, if you know a member that would, please tag them here. I’ll go ahead and add @NickTransmissions .
