main vacuum source for heat/ac
86chevyk20
Buffalo
Liam
SO i got my heater core back in along with the new controls and i was thinking about the vacuum lines today.
I dont have any vacuum lines that are going from my engine through my firewall.
SO what is my vacuum source for my ac/heater controls? Where do i need to connect a hose too?
Thanks
Liam
Should be a place on the intake manifold behind the carb. Threaded into the manifold with a nipple/nipples.
86chevyk20
Buffalo
Liam
i have all after market. I have a edelbroke 600. i dont know where the vacuum line is. i dont see a vacuum line that is coming through the firewall
chengny
These images my help.
Do you have a vacuum chamber? It isn't absolutely necessary but helps smooth out the controls during times of varying engine loads.
For a vacuum supply, I tee into the transmission modulator line in the back of the intake manifold. Be sure and install a check valve where indicated. Also included the tubing schematic for dash side:
thefoxtango
