LS Swap Fuel Pump
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Ep381 with a 87-91 k5 gas tank and sending unit to send the 60 psi to my efi.
Blackbeard44
Washington State
andy
6.0 LS
thanks for the info, I am going to start rounding up parts
Blackbeard44
Washington State
andy
6.0 LS
is the flange on the top of the tank the same?
86 C10 Shortbed
Ohio
Mark
5.3L
I used the Corvette inline pump with the filter mounted before the pump, I should have put a secondary filter after the pump but I've had no issues. I have dual 86 tanks with the standard sending units, going to the standard GM dual tank valve and standard switch on the dash.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I use a walborro 550 mounted on my frame,corvette fuel filter has built in regulator, I am able to still use both tanks with no problems, I have been driving my LS swapped truck for 3 years now and it is dependable, I am going to look into putting pumps on the hangers in the tanks, I just have to come up with a way to switch the return into what ever tank I am using
Does that pump mounted on the rail pull gas from the saddle tank?
Blackbeard44
Washington State
andy
6.0 LS
it does it pull fuel from the distrubition valve where the tanks tie in at, I used a corvette fuel filter with built in regulator and return line to feed the return back in the valve as well
Blackbeard44
Washington State
andy
6.0 LS
in the future I want to hang pumps into the tanks, i really like that idea, than if one fails there is a back-up.
and also if I end up with a supercharger it would be nice to have a dedicated E85 tank
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I have a single tank.
Blackbeard44
Washington State
andy
6.0 LS
it should be easier, depending on if your motor has a return from the fuel rail, some LS motors have a return at the fuel rail, some dont.
most carburated trucks should have a return line from the fuel pump
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
The 5.3 I have does have a return line.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Blackbeard44
Washington State
andy
6.0 LS
yes you will not have to remove the tank, that pump will bolt to the frame, eariler on in this thread other users listed part #'s for replacement hangers with pumps that will provide 58ish PSI for an LS motor
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Thanks. Looking up those part numbers.
Blackbeard44
Washington State
andy
6.0 LS
I think, I am pretty sure the mid-late90's vortec 350 truck motors required the same PSI of fuel pressure the LS motors need, and I am sure that I have read on this forum somewhere tjat those hangers are a direct replacement, but do your homework.
my 1985 fuel gauge is 30-90 ohms, 30 at empty, 90 when full, I imagine yours will be the same
thatgermanguy
