- Apr 11, 2017
- kansas
- Rick
- c20
That switch being bad would not cause an extended crank. What that switch does is takes over if you lose your normal fuel pump power. Then if it is,say your fuel pump relay is bad that switch will close when you have oil pressure. It is a back up
In case you lose fuel pump power. That's why it causes the extended crank, if your relay isn't working you have to crank until you have oil pressure,which closes the switch and provides an alternate power supply.
