Low idle in gear causes gauges to drop.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
So i have noticed that when my truck is warm (which is rare cus its negative out side every day) and i pull up to a stop she idels down where i like it but then my gauges drop and the lights dim, if i just barly get on the throttle they all go up, so basicaly is this normal? or should i search for a bad ground/power wire? Also prolli the main reason i don't think its right is cus then my blinkers are FUGGGIN slow, then the speed up when i give her a bit of gas. I dunno wat its ideling at but prolli around 500 in gear stopped. (new batt. new alternater)
animal
Lee
c10 silverado
350ish
Sounds like you need better grounds or do "the big 3."
I agree with Retro. I would probably look at the "big 3" upgrade. There's a sticky on it.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Big 3 would be the first thing I would do and if it still does it, your idle needs to come up a couple hundred rpm. If it still does it after that I would be looking at the alternator. A higher amperage alternator for vehicles equipped with more power accessories like power seats, mirrors, etc would put out more juice at lower rpm compared to your stock alternator.
Kapdin
North Dakota
Lance
help me out guys, i search for big 3 and come up with nothin.
msharo
