Lost ignition!
suburbangirl
Colorado
Justine
K1500
6.5 Diesel
Today I went to pickup my Suburban from a friends who stored it while I’ve been away. He’s lost my one and only key. Call a couple of automotive locksmith but seems no one has the skills to re key it.
Is it difficult to replace the ignition switch?
I hate messing around with anything electrical.
Any advise would be greatly appreciated.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
What year is it?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
It is actually the lock cylinder (ignition switch is at the bottom of the column)and it is not a difficult job if you have access to a steering wheel puller, a lock plate puller, and you aren't afraid to take out the turn signal switch.
Quite a bit harder without those tools, but not impossible. :burnout:
Some pics from my 99 Camaro SS.
If you have access to any other GM keys try them all wiggle jiggle twist jiggle,sometimes you get lucky and the key and tumblers are sloppy enough to start with a different key. Drive it that way for a week or two,see if your key turns up.
75gmck25
Northern Virginia
Bruce
If you can jiggle it enough to get it to turn the key, then you should be able to access the release and remove the lock cylinder. Then just buy a new lock cylinder, or have a locksmith make you a key that matches the one you have. Process for removal of the lock cylinder varies a little by year, but you don't really need any special tools that I recall (as long as you can turn the key).
Some pick and pull yards have a vendor that makes new keys to match old locks, since the keys to junked cars are often missing.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
My keys for my 78 square and 91 s10 usually go into each others locks and ign. My s10 key is so worn out i can take it out while its running.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
While your method might possibly work with the older style of lock cylinder to remove, I suspect you will have a tough time loosening the set screw style that way. Not sure these cut off dates are correct but the 2 different styles shown are.
Some additional how to info :
yellow eyed Andi
