Lock nut for rockers so tight its breaking tools
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
Turns out it was waaay worse than I thought. Ill not be using Engine Builders Inc. In Trussville AL for anything in the future.
Found one of the cam gear bolts(the mismatched ones) was broken almost all the way through. The head fell off in my socket before I even put any pressure to it.
Furthermore the pushrods were mismatched as well with one being a completely different style(smooth end vs the kind with the ring machined into the end). I know a pushrod is a pushrod as long as the diameter and length are the same but, cmon...really. My brother paid good money to have the engine built and im finding all kinds of BS.
On top of all that the guide plates had to be adjusted because you could see the obvious scarring on the pushrod from contact. Oh ,and the oil pan bolts were hand tight.
Im lucky this engine only has about 2hrs of run time otherwise there could have been some real damage.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
Ball ends on hex keys for 3/8 square drive's don't seem to last under torque at all. My friends dad has managed to break almost every ball end square drive allen with their m12 fuel ratchet. If you can find a set of hex drive bits that use a straight bit with a set screw rather than a necked down one, this way if you break them you can pull the broken one out and cut a new piece for it from a donor hex key.
Something like this
the next set I buy will be straight cut and lifetime warrantied.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
The saga continues...The pushrods are three piece welded ball type and are being used with guide plates. ONe of the 16 was the proper one piece heat treated style so im having to order pushrods now.....AAAhHHH
JoeyPepperoni
