Locating odd sized bolts
TX87R10
Txr10
Hey guys -
I'm working on another car at the moment that I need a 3 and 11/16" hex head 18NC bolt for. 3 1/2 and 4 aren't working. I've checked McMaster Carr, Fastenal, all the local hardware stores, but so far no dice.
Any ideas on locating odd bolt sizes like this? I would love to pick it up locally so I don't have to wait a week from a random ebay seller or something but...
Big Chip
Michigan
Kevin
C35
Hey guys -
The dealer maybe?
TX87R10
Txr10
The dealer maybe?
Possibly, I'll check. It is for '66 mustang water pump so hard to imagine they still use an odd size like that but it's worth a shot
Big Chip
Michigan
Kevin
C35
That does definitely make it more difficult. Maybe try a junkyard if all else fails.
TX87R10
Txr10
I see online people sawing to saw it off but I can't imagine that is great for the integrity of the bolt.
Doppleganger
OH-MI: Just like it sounds
I had a similar issue with a front cross member to frame bolt on an old Euro I was working on several years ago. Was an odd duck metric length. I got a longer bolt, screwed a thread die / chaser onto it high up toward the head, then cut it with a grinding wheel. Used a bench grinder to get it where I wanted it, then removed the thread die which cleaned the threads perfect. UFB how much a single bolt of length and size goes for now. I just bought a 14mm by around 5 1/2" and it was $7. wtf
Its a Plan B perhaps.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
It's not going to hurt it. If you have to cut one down remember to file or grind a 60° chamfer on the end.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
+1
Have done exactly this several times when I needed a bolt or screw that was a touch too long.
Worked out well whenever I had to do it.
Keith Seymore
Motor City
Keith Seymore
4.3L
+1
+100
One of the things Roger Penske and Mark Donohue would do is cut the extra length of all the bolts - for a mass savings.
Part of the "unfair advantage".
K
Auburn, Washington
You could stack up a few washers if you’re still against cutting a bolt to length.
Nothin says “I fixed this myself” like extra washers! Lol
But it works.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I 4th or whatever it's at to just cut a bolt. Done it many times, no issues. As said before grind a chamfer after you cut it and maybe chase the threads with a nut first.
1973c10
Don
Could you use a stud and nut
bglendon
