LMC Truck Battery tray doesn't fit
Rick Dobbins
Temecula, Calif
C25
My '77 was rusted and I put an LMC tray in with no problems. Well, you can't put a monster battery in it, but that's OK. Don't need it anywho.
thecantaloupeman
US
Dawson
C20 Silverado Camper Special
Interesting. I ordered the side hanger assembly and it helped a little bit. Still doesn't fit great, but at least the hole lines up. I'm still not sure it is level but it looks better. The radiator coolant overflow reservoir didn't line up great either so it isn't really straight, but it fit with a little bit of drilling the plastic hole bigger. Also the edge of the battery tray isn't parallel with the side piece. It seems like it is more of an issue with where the screw holes are. Maybe I am just an isolated case or something weird, but it is good enough. It is a bit annoying, but it should be alright. I'll post pictures later on.
Kim Burke
Northern IN
Kim
C1500
These forty plus year old trucks can look very original even if there was a collision repair 35 years ago. I’m convinced that’s been some of my misalignment issues. Just my 2 cents
goodwrenchca
