LMC Door / Interior Panels
68post
very, VERY, limited access member
Indianapolis
Tim
84 K30 SRW Silverado, 85 C20 C6P
454, TBD
Nice Craig, didn't know that those are available at my fav parts hse.
Doppleganger
OH-MI: Just like it sounds
Their basic door panels are decent quality and fit well, although there is no recess for a cloth or velour panel… the ribbed channels are formed in the hard plastic. So you can’t upgrade to a Silverado/Sierra Classic trim level. For my High Sierra, I bought the basic panels and all the trim/chrome/pocket/carpet ..you don’t need to buy an additional inner window felt seal (it’s already on the door panel)
Yes, the other pieces are of good quality. ABS plastic Headliner- A & B pillar trim - upper front/rear and side headliner trim...
color match all pieces for a consistent and factory look.
Did you have to paint any of the interior panels - and if so, what did you use? USA1 has the charcoal spray paint for about $20/can - haven't looked into if it needs primered, etc yet.
I see LMC has gray but it looks light. Debating on weather I need to get (bare) black or their painted gray to make into charcoal.
Thanks again for the info.
68post
Indianapolis
Tim
454, TBD
I saw light and dark gray in some of the panels on RockAuto
FireTruck1984
Michigan
Ted
1984 and 1984
Yes, the last interior I restored, I used the ColorBond Blue from LMC. I sprayed all the trim pieces and dash pad/door panels.
They don't have all colors..Classic Industries also sells a color match spray in factory colors.
3 light coats of color, then mat or satin clear.
86c10twotone
MD
Roy
Just bought the door panels and headliner. Both are high quality and look good. I added the carpet, chrome strip, and carpet trim piece to mine. Wanted the fully dressed door panels from the other place, but was not willing to wait the 12 weeks + to get them.
I just bought an entire interior from lmc that arrives Monday. I’ll let you know how it goes and the quality.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
@Doppleganger the Covercraft door panel I bought are the dark gray versions. It matches the Charcoal sunvisors I got from USA-1. SEM makes interior paints too. Same type of prep as described above.
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
What was the other place and how dressed were they?
big_blue_burb
