LMC Dash Pad Supplier
John Milner
Oklahoma
Scott
My dash pad from LMC was a very nice part. It had a steel backing like original. The dash isn't wavy after it sits in the sun and it fit very well I thought. It is a 79 dash.
If you want to get your original dash redone, another alternative to Just Dashes is Al Knoch Interiors in El Paso, TX. They do a very nice job on 70's Trans Am and GTO dashes and are much cheaper than Just Dashes. Usually they have a quick turnaround too, like maybe a month or less. I would imagine that they could do a Chevy pickup dash too if you send them a core. It might be worth a call.
Good to know, thanks!
fast 99
Spokane, Washington
Has anyone bought an 81 up pad recently? One I purchased [a Dashes Direct part] did not fit the cluster bezel area upper left corner. Ground some material off the bezel. Not going to replace it but need a pad for another truck soon.
Soundmound
North Central Washington
Dave
Scottsdale
I bought one from LMC last winter. It was dashes direct supplied and might have a similar corner issue. I just test fitted it before everything got shelved so I can't say for sure.
99tan99
