molus
- Jul 12, 2023
- new zealand
- morgan
- k20
Good morning all the way from New Zealand. I’ve just bought this K20 as a fresh import into the country.I’m looking at replacing the suspension as it’s current hacked and welded.
I’m thinking of doing a shackle flip in the rear + a 2 inch lift (56 inch leafs). And 6 inch in the front.
What’s everyone’s recommendation for smoothest ride and good articulation.
I will not be hauling any weight, will be mostly off-roading. Will be adding a Baja style bar with lights and winch on front. I plan on keeping it on 37/12.5s. I’ve also adding a bushwhacker cut out flares. (Tyres can’t stick out past guards in NZ)
Thinking about a sway bar disconnect and crossover steering kit also. I have to import everything by container so only want to do this once.
