lets see your heater hoses!
FireTruck1984
Michigan
1984 and 1984
PrairieDrifter’s Zip Tie solution looks real good, it’s probably all you need
I ask because I have buckets of bits and ends that a large portion seem to be stock from squares, and i might just have one laying around that I can use. I ask because I found two that looked like what I mentioned.
Turbo4whl
Downingtown, PA
Wayne
1981 GMC no AC
Got to like a good breathing 2 snorkel air cleaner.
Heater hose, 2 rubber-coated clamps and a bolt. The green strip heavy duty heater hose would not fit well in the smaller factory clamp.
What caused your truck to have 2 snorkels from factory? Increased hot air for the air filter valve? or just more fresh air intake on that big block?
WesN
Edmonton Alberta Canada
Wes
C1500
is that a corvette air cleaner or was it an option on our trucks?
The knockout was in the rad support on the drivers side so got all the parts from the right side at a wrecker and built a factory looking dual snorkel. It all looks stock.
Turbo4whl
Downingtown, PA
Wayne
I added the second snorkel. Yes the BB needed more air. Believe it or not, I found on a Dodge van a factory 2 snorkel system. On the rat engine, when still warming up and the heat stove is closed to the larger cold air intake, if I stabbed the throttle there was hesitation. This I found out this was because the flap in the air cleaner snorkel would take that time to slap open.
The dodge 2 snorkel, had the second snorkel flap vacuum ported directly to manifold vacuum. No heat stove on that one. As you stab the throttle, low manifold vacuum the second snorkel opens right away.
I went through great lengths to make sure I could start that engine stone cold, and then drive it! Oil pressure up, good, go.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Well looks like I have another project
79dentside
Kansas
Brandon
GMC Sierra Classic
Mine is a little bit of a mess. I got zip ties holding my stuff taunt. I need to get a fender-hose clamp to hold them down, but this is what I got.
I cant find anything in the slightest like it on lmc ;(
are one of these it?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I want one of these setups.....
zapattack
