LED exterior light conversion! not going well :(
Scott91370
Burleson, Tx
Scott
Sierra1500
I just used LED on headlights and auxiliary fog lights where it really matters and kept the rest incandescent. I have seen too many threads about issues LEDs in turn signals to even want to try it elsewhere
That's what I did as well as backup bulbs. I did start with other lights as LED but didn't care for it in the housing because they were to pinpoint and didn't fill out the lens with light like an incandescent.
daveca
earth
dave
blazer
This bit the 1980s Honda Goldwing owners hard, install LED lights that draw almost no current and the voltage regulator freaked out.
The 6 amp draw of the running lights was required to stabilize the regulator.
LEDs require a minimum voltage drop to operate, the units will bd expecting 12-14 VDC. There may be enough voltage drop in old wiring CONNECTORS to cause problems.
It may be necessary to power them thru a relay from IGN or BATTERY
I just used LED on headlights and auxillary fog lights where it really matters and kept the rest incandescent. I have seen too many threads about issues LEDs in turn signals to even want to try it elsewhere
Mitigateable but to a lot of hassle. I like stop lamps being LED
ChevyTruckLove75
Hamilton, Ontario, Canada
Julian
OK UPDATE AND SOLVED!!!
wow folks! I figured it out and of course with some good knowledgeable help from everyone here!! although I'm not completely out of the woods but here it goes!
so I switched every LED light on the exterior of the truck and put brand new bulbs in all the places., after jiggling a few connections to make sure everything was snug I managed to get everything working as they should! seems I had dirty connections in some or all of the sockets...
so after getting the incandescent lights to work I decided to go ahead and plug the front side marker lights in to see if I can get them working and here is what I found/discovered!
so with no headlights on., I got the side marker signals to work., they too also needed to be jiggled into the sweet spot where they stayed working! when I turned the headlights on I get no power to the side marker lights. So, I reversed the LED plug and boom! I had signals and running lights on the side markers.
so basically, in order to have the LED's working I need to reverse the plug in., simply because LED's only run current in one direction and the way these trucks are wired is for two hots to be running into the marker light bulb which is current that runs in both directions...
my guess now is to run both hot wires to the positive lead of the LED and run a separate ground to the negative cables.,., I dont know for sure but I feel like that will work...
any thoughts? or maybe this is where a resistor comes into play? not sure but Im going to splice both the running light and signal light wire into one for the side marker lights and a ground.
I'll be back to explain how it goes in the next update!
ChevyTruckLove75
Julian
alright UPDATE AGAIN! so Do NOT I repeat DO NOT splice the wires like I mentioned in the above to put both turn signal and running lights to the positive LED wire., it was a disaster., all it did was give me full lights on all the time with no signals because obviously the running light being on all the time didn;t allow the signals to flash .... so I removed it immediately., BUT, I still decided to go with the LED marker lights because they are nice and bright and they are part of the entire housing for the side markers. But what I did notice is , remember how I said with the headlights on, the running lights for the markers were DIM in comparison to the rears? well its because of the LED front turn signal bulbs, I tried the LED's again just to see if I could back to them but they were the culprit for causing the side markers to go dim .
so I'm keeping with the front turn signals and rear tail lights incandescent and the front and rear side markers are LED's. Now everything is working great and as they should.
Turns out the LED side markers are a positive and negative wire only., therefor I had to give up one which was the turn signals to the side markers when the headlights are off., which I dont really care that much since during the day they are not really that big a deal but with the headlights/running lights on, the turn signals on the marker lights work! I can live with that because at night they need to be working! and when Im not using the turn signals the running lights are on! so far all is good, if anyone has an idea how to get the turn signals working while the headlights are off please let me know., resistors? diodes? relay?
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
they make polarity insensitive 194, ive never used them but if they work good ill definitely be using them
They work great, have them in the cab top lights of my 1 ton flatbed dually, as well as the front corner lights (gmt400 K3500). I also run led tails (full panel), bed markers and headlight inserts on that same truck. Tails and bed markers are from “Hazard Fraught”, work perfectly.
IF YOU READ OUR REPLIES BEFORE YOU WOULD HAVE SKIPPED ALL OF YOUR FINDING OUT.
AND YOU CAN USE THE PRODUCT I MENTIONED TO NOT TOUCH THE WIRING AT ALL AND HAVE ALL THE FUNCTIONS YOU ARE TALKING ABOUT DECIDING WHICH ONE YOU WANT.
you are unlikely to be pulled over for it, but using the LED In the sidemarker either way is technically illegally because whatever condition it is that doesnt function, is a required function. Either the sidemarker functionality at night or front turn signal visibility
butlike i said, unlikely to get many tickets in these situations.
JUST BUY THE BULBS I MENTIONED. problem solved.
Dejure
Eastern Washington
Kelly
C15
If my truck wasn't my daily, I'd trash about 99.9999% of the wiring (leaving only a thought) and wire the thing up from scratch. From first hand experience, it's safe to say I'd have a pile of wire for the salvage yard.
From there, it'd be simplistic wiring. Maybe a diode or two so I could control electrical flow. That is, use on bulb for two functions (e.g., stop and turn) by stopping the current from flowing from the stop to the turn, and visa versa, since diodes only let current flow one way.
The only relays would be:
(1) the solenoid;
(2) the flashers; and,
(3) turns.
The windows and such would not have relays. Just good quality switches.
Circuits would be limited to:
(1) Tail and marker lights
(2) Head lights (high and low via the dimmer)
(3) Turn signals and markers (diode)
(4) Dome (actually, better than stock)
(5) Under hood lighting
(6) Ignition circuits (start and run)
(7) Stereo
(8) Dash and shifter lights
(9) Turn indicators and flashers (diodes)
(10) Fog lights
(11) Run lights
(12) Heater [and air, if applicable]
(13) Horn
(14) Backup lights
NOTES: (1) The headlight switch would provide segregation between tail-marker and headlight circuits; (2) Easy access fuse & relay box, with ample spots for future ignition and straight power sources; (3) Breakers for main supplies; (4) plug in diodes would provide crossover protection between circuits; (5) Protecting tubing everywhere
Yes, it'd take more wire than Detroit used, but the simplicity from there on . . . . And many of the LED issues wouldn't be issues.
Dejure
Eastern Washington
Kelly
C15
Gotta love electricity. Go from household wiring to automotive and you have to turn some of it backwards (i.e., black goes from ground to hot).
Then there is the nature of electricity and components, which is, weird things happen. For example:
(1) By the markers running through the other bulbs for functions, they should last longer, since they were built for with future sales in mind, running at a given voltage, but, by powering them through other bulbs, the voltage is reduced and they should last longer.
(2) I had a feed back in the dash, when I stepped on the brakes. both turns would come on. ???? I scratched my head and went for the obvious - check bulbs. All of them read good. Then I looked at one and noticed something amiss. One of the double element filaments had opened. The tension it was under caused it to move wildly, and it hit the other element, where it welded to it, creating a feed back circuit between tail and turn circuits.
If my vision hadn't been good, I could have been scratching my head for a while.
(3) Then there is the raw power of ignorance. About fifty years ago, my dryer died. I had it half torn apart, trying to figure out what the problem was, until I learned it was a 240 volt appliance with two breakers, and the breaker used was an improper one lacking the double lock out. Reassembled everything, hit the breaker and never had a problem again.
(4) Years after the dryer intermittent failure, I came to learn all about loathing intermittent from working complex electrical equipment for the feds (civilian, employed by the Navy). Chasing such things has made even women bald (hair pulling).
Tonimus
Phoenix
Tony
C10 Suburban
Non polar T10s are what you want for side lights.
Broken85
Cumberland, NJ
A
1985 Chevy C10
so I decided to do the switch to LED's because I was having this same issue with incandescent so I figured LED's might solve the problem BUT, boy was I wrong lol
so at this point right now all of the exterior lights have been changed to LED's., including the LED Flasher module located in the fuse box.
I purchased new side marker housings with LED lights already installed inside the housing for the front and rears off of AliExpress, reviews looked good and people have plugged them in and good to go!
these new lights, they have a red and black wire, but as I understand the side marker lights are both hot., blue for the signals and brown for the parking lamps. either way I plugged them in so the red is on the blue side of the plug and the black goes with the brown.
So, my issue is this. With the headlights off, all lights and turn signals work good except the side marker lights.,
the rear side marker lights are lit up as they should be but the fronts are completely off, no signal flashing
next, when I turn the headlights on., the front marker lights turn on but are very dim/barely lit up., when I turn the turn signals on the front side marker lights flash as they should.
so with headlights off, the front side marker lights do not flash with the turn signals
with the headlights on the front side marker lights do flash with the signals but the DTR lights are dim/on but barely visible.
I also notice that when I turn the headlights on the dash turn signal light indicators illuminate very dim/barely on just like the front side marker lights do.
also, I notice the front drivers side marker light wiring has two wires, a light blue wire and a brown wire, they both go into a harness and travel to their respect location but the brown wire has a split/joint wire attached which is also brown and it's just hanging and not connected to anything. doesn't that wire need to be connected to the turn signal parking lamp wire? or is that possibly there and was used to feed some other light system? for say, fog lights or something?
anyway., Im completely stumped and can't seem to figure this out :(
I noticed this forum has a lot of pros here in the electrical vehicle system so I'm hoping to get some help in figuring this mess out., what steps I should take? should I try and go back to all incandescent bulbs and see if its a LED issue? maybe I need resistors in line somewhere?
or should I just re-wire the front side marker lights directly to the front turn signal lights!?
let me know if there are anymore details that can be helpful to figure this out!? thank you!
The reason the dash blinker indicators glow with the headlights is also because of the LED bulbs. The 1157s are basically two independent circuits; one for marker and one for blinker. The LEDs are not two circuits. They are one circuit with a high (blinker) and a low (marker) so when you turn on the marker lights, the voltage is bridging to the blinker circuit across the LED bulb and illuminating the indicators on the blinker circuit.
jtward1954
