leaf spring bushings
79Scott
N37°20’26” - W77°40’34
Scott
C10-Silverado
305ci
Hey guys,
Please excuse my ignorance but what is a rear forward spring bushing in regards to rear leaf springs?
I assume the front bushings are different than the rears on the leaf springs?
Thanks
TubeTruck
East TN
Denis
Suburban K10
LQ9
The front of the rear spring, the solid mount side.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
It is in fact the bushing that resides in the front eye of the spring.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
And yes the front is a little smaller than the rear if I recall correctly.
79Scott
Scott
C10-Silverado
305ci
So I would need two sets of bushings, one set for the front of the springs and one set for the rear of the springs?
One end of the spring uses a fixed mount, so it has a single bushing to allow it to rotate in the mount. The other end of the spring must be allowed to change in length as the axle moves, so it has a shackle mount with a bushing in each end. On a 4WD squarebody there is a total of 12 bushings (3 per spring). They are not all the same diameter.
MTsquare
