crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
Comparing a K truck to a C truck, to a 4runner, to their friggin bayliner or whatever is rediculous. If you take a K10 longbed/350/th350 and K20 longbed 454/TH400, or whatever OD trans you want but THE SAME in each, that would be a more likely comparison. And comparing snow plows isnt the same either. You're working the truck, pushing a load. The 454 will work easier than the 350 no argument from me. But if you have 2 trucks side by side, 2WD, longbeds, one with 350 the other with 454, both with OD trans I REALLY doubt the 454 beating the 350 on fuel economy. Comparing a 4WD with a 350 and unknown gears/t-case/tire size to a 2WD with 454, again with unknown gears/tire size is not a real comparison. More rotating parts in the t-case robs hp and hurts fuel economy. I mean if you want to play the argument that way let's compare a 3+3 dually 4x4/454/4.56 gears to a SWB 2WD/350/3.08 gears and see who comes out on top there.
