K25 ON A K10 FRAME
mpilon
quebec
meli
gmc sierra custom deluxe K25
hi! i bought a 1976 gmc sierra K25 with a 350 manual transmission with a low-1-2-3-R am curently trying to rebuilt the truck because my frame is not in good shape, i ve found a 1975 K10 frame thats have a TH350 with a 350, am trying to see if i can use this frame ( the K10) and put my mecanic on it. i know the wheel base is not the same because mine (K25) have a long box and the K10 have a short wheelbase but i can deal with that.
is there anyone who know if it will fit on it,,,
nvrenuf
Mobile, Al.
Everything from the cab forward will bolt on but there are some things that will need to be addressed;
- obviously you'll need a short bed
- you'll probably need 16 gal tanks, I do not believe the longer 20 gal tanks will fit a swb
- rear driveshaft will need to be shortened
- the tcase crossmember will fit but have to be relocated since the trans/tcase combos are different lengths.
- rear wiring harness length (shorten or tie up the excess)
- rear frame brake tube length
- rear spring lengths are different
mpilon
quebec
meli
thanks
mpilon
quebec
meli
i waswondering if the frame durability is the same, like is the K25 one more strong, i wanna do an off road truck with it do i need to add plate to make it stronger
nvrenuf
Mobile, Al.
Technically, I've read that some 20 series frames are thicker but we're talking about MM's not a significant amount. Anything that will damage a 10 series frame will damage a 20 series frame.
You can always box, reinforce, etc but there's a domino effect that's hard to stop. I would highly recommend both a steering box brace and a weld on reinforcement plate kit, 99.9% of square body frames are cracked or will crack at the steering box so these will be money well spent.
78crustdumdlux
