PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- 84,79,77,76,70,48
- Suburban k10, bonanza k10, k30, k20, c10, gmc 1/2ton
- 350, 350, 350, 350, 350, 350
I disagree with the final statement. Maybe a modern 1/2 ton to a k20 would be comparable, mayyyyyybe a single wheel k30 but that's a big big stretch(with a small block) definitely not weight capacity, definitely not a dually.I can remember when NFL linemen were getting up to 300lbs and fans were like "OMG this is amazing!" Then 320lb, 330lb and some at 350lbs.
Aaron Gibson, who played briefly for the Chicago Bears, set the record for the NFL and weighed 410 lbs at the time.
Huge players that were fast and quick. Then it became evident that they could not sustain longevity in the league. Doctors were coming out and noting that the human skeletal frame could not sustain the weight and physical exertion that was being put upon the tendons and ligaments.
You are asking if you can take a 185lb running back to the Golden Corral every day and switch him to nose tackle.
I drive my 73-87s more than anything else I own because they are fun, and I work them often and hard, but even a 1 ton squarebody does not equal the capabilities of a modern 1/2 ton Silverado.
Everybody thinks they need to tow everything at 80mph. Maybe that comparison, instead in comfort and stock horsepower is more on par.
But as for towing capabilities, not so much. I don't mind driving 55-60 everywhere..
I see so many modern half ton trucks squatted down to the bump stops with empty trailers. If you love your front end floating down the road doing 70+ then the point of all this safety talk is moot.
1/2 ton trucks should stick to small boats, jetskis and atv trailers. HELL even some of the trucks are working past their limits with some of these average sized boats!
Again, I don't get why everyone has to haul ass doing 70+ while towing. Ive seen so many trailer sways, terrible towing etc. people flying past me with 20+ ft trailer minimum these days, while I'm doing 4 over the posted limit.
People are scared of semis, no no, be scared of the rv's/motorhomes, then the work truck douches, then the tow once every three years people, THEN semis.
DONT even get me started on the 40ft campers WITH a boat, pupped onto the camper doing 70+ people are insane.
