K10 fuel line for Holley sniper truck has dual tanks but I’m buying the hokey tank with the efi fuel pump it I’m needing a line kit for just one tank
wildone454
wv
cody
Looking for a fuel line kit preferably steel from the tank all the way to the Holley sniper 2? What have y’all done and used to hook up here’s the tank set up I’m getting
jh86
united states
Jon
I did not find a kit that did this. There are universal kits with different components; flex lines, filters, etc.
I made my life difficult by wanting hard line along frame similar to original.
So I did ss flex from tank to frame. SS hardline along frame, ss flex to throttle body. I would not do this again.
I’d get a nylon flex kit and run flex the whole way and be done with it.
If you are set on hard lines. I suggest buying (2) 3/8 supply lines from inline tube and mod from there. 1 as supply the other return. I did not do this, bent my own which was a learning experience. Not entirely happy with how it turned out.
Lot of videos showing how people run their lines.
jh86
united states
Jon
Also, it looks like you didn’t get the Efi specific tank. I think you will need to add a supplemental vent into the tank. The Efi tank separates the float and pump which leaves space on pump flange for vent connection to be included. I don’t think your all in one float/pump assembly has the vent connection
1990 burb
