- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
My skidsteer has a 20hp k series kohler, and i planned to replace it with a predator of 24hp but 6 less foot pounds of torque. It direct shafts to a hydraulic pump.
Of course, i would need to do fab work and couple new engine(different shaft diameter) which i had a thread ab.
but, I learned that crankcase breathers, rings, valve timing, etc could be my issue rather than mechanical wear.
And im inclined to believe it.
It leaks out like a MFer, but when its not running the leak stops within 12 hours.
It burns oil like a MFer, but its also covered in oil, sludge, grime (hot engine) and the crankcase might be overpressurized, blowing by rings...
It also sat for 20 years after the points failed and it got parked.it had some nasty oil inside.
So maybe I have an engine, an old heavy iron flathead, that cant breathe and the oil route is past rings, out of seals, or elsewhere.
It also shoots tiny bits of oil out of air filter housing... it will make everythign oily.
but that could be valve timing.... intake and ehxuast are both open at same time in anyway, exhaust shooting oil vapor up past carb?
Would explain why old carb was grimey.
So, anyone have experience?
I dont have much internal engine experience but to pull the engine wont be much. finding online stuff for the 2 cylinder is hard. where is a breather at? any tips? other things to look at?
i cant reach it, but i seemingly have a k series kohler in my engine stash, but i wouldnt know its displacement. it just outwardly appears the same. if its a parts thing, maybe you never know
